76 - 900SS ecletric ignition
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Hi All
Can someone tell me how reliable the original electronic ignition system is on a 76 - 900SS ???
Can one covert to the Bosch system without to much trouble or is it not worth doing ?
abmartin
Post by abmartin »
I believe they have the same electronic ignition system as the 860GTs and GTSs. Some people claim they are not particularly reliable but I never had any problems with my 860. The ignition advance is supposed to be more abrupt than with the Bosch system.
I doubt very much that you could convert to the Bosch system.
Jon
Post by Jon »
Was it you who was using the Ignitech system on one of your bikes Martin?
If so how did it go?
If not I am running one on my VFR and find it pretty good. http://www.ignitech.cz/
regards
jon[/url]
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
MartinMille BANNED
BANNED
No not me , I have never owned an SS before
I did speak with Gowies yesterday and they do have some sort of mod they can do to make the std ignition more reliable , will have to look into that one as time gets a little closer
Jon
Post by Jon »
Thread on the Ignitech system here if you are interested.
http://www.ducati.ms/forums/showthread.php?t=34482
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
MartinMille BANNED
BANNED
Interesting read to say the least ,
I like the fact that you can fine tune the advance curve via a laptop with the software supplied once the unit is installed
I have sent them an email with some questions of my own , this might well be a good system to buy as the ignition modules are no longer required
Thanks for posting the link to the other forum her is the link to IgniTech
http://www.ignitech.cz/english/aindex.htm
Martin, The original Ducati electronic ign. was very unreliable.Even fresh out of the box you could lose one or both cyls. when hot. I once went through 3 stators one race weekend. If you have one that works minimize the load on it by running your plug gap at .020". It appears the Ignitech syst. is for the later Bosch systems. Steve used to list a replacement setup made in Germany I think it was made by DMG. There is a thread on this forum somewhere about it.
MartinMille BANNED
BANNED
Thanks for the info , far out its not cheap ,
I wonder if Dyna make something
Anyone on the forum using the DMC set up on there old girl ?
Jon
Post by Jon »
wdietz186 wrote: It appears the Ignitech syst. is for the later Bosch systems.
The Ignitech only uses the pickups from the original system and coils of your choice, yo can replace the pickups and trigger as well if you want.
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
nottonight68
BLABBERMOUTH
Post by nottonight68 »
hey guys as you know im doin some stuff on my ss
although my dreaded stator plate was ok last time i rode-i would luv to find the definitive answer to this problem-ive been told many solutions
everyone seems to have ideas-is there a difinitive solution-bearing in mind i want to keep this thing looking original
MartinMille BANNED
BANNED
Steve the way I read it, this Ignitech unit hides anywhere you like you could even leave the ign boxes bolted to make it look the same and since it utilizes the original pick-ups the wire leaving the side cover will remain the same , there is a discount to be had if more than one unit is bought go you halves if you like after I find out a little more about them
The Ducati electronic ign. dosen't use seperate pickups like the Bosch system.The whole mess is potted in the stator assy. It has coils that generate voltage to fire the ign. coils and trigger coils to tell them when. It may be possible to use the trigger side if you can determine which of the three wires does what.But I think even they are interconnected. And given the stellar performance they have provided I don't even think they are good for paperweights. The DMC setup would be unnoticable if the control box is mounted up under the tank. I remember a company called Silent Hektik also has a similar setup for the early 860,900. I have an old Lucas Rita system on my 900 and it works pretty well but dosen't look original and is not available any more anyway.
MartinMille BANNED
BANNED
Was it the electronics in side the engine that gave up or the ign modules ?
Martin, It was the stator plate behind the flywheel. The red ign. boxes never seemed to fail.But that might be because the stators never lasted long enough to tell. I've got about six of them lying around here somewhere. If anyone needs some PM me. Bill
MartinMille BANNED
BANNED
Is this kinda what you are talking about ?
