Hey Everyone,
I need to re-torque my head bolts on my 450 RT, my manual
says that it should be 300-350 ft/lbs. I believe this is a mis-print.
I think that this was originally in newtons and the proper Torque
should be somewhere around 67 ft/lbs.
Can anyone out there confirm this and or tell my the correct
Torque that I should use to tighten these things up.
Also does anyone recommend using some kind of seal a gasket
between the head and the cylinder ? The manual doesn't show a
gasket and there wasn't one there when I open it up. Or should I just
leave it like the manual shows ?
FullHedge
Torque specs
FullHedge
Torque specs
Thanks Robin172,
I will make sure it's clean.
FullHedge
FullHedge
