engine rebiuld
- BLABBERMOUTH
engine rebiuld
got quoted au$10,000 for motor rebuild- complete replacement of all parts including gearbox, which i was told would be no good after 32 yrs &90,000 kms. anyone have any thoughts/experience recently on this. how far do i take motor resto?
- SSD900 Darmah
You probably need to tear down the engine at least enough to inspect critical areas for wear, such as the valve train and bevel gears. I have heard that the bevel gears last an extremely long time and can be shimed to take up tolerances. Seems like you would not have to replace every part of your engine unless you just have to have everything brand new. Most of that 10K cost is in parts!
- BLABBERMOUTH
I dropped 5th gear at about 5000rpm, took out 4th, 3rd, mainshaft, layshaft, main drive gear. All new bearings in main case, new big end assembly, new oil pump, Ron Young did the work, added his own modified oil screen seal, re-shimmed all the lower bevel gears and modified the ignition pickups. While he had the bottom end, I did all new valves, recut seats, new rings, overhauled carbies. yep, if you had to fit new pistons and pay for all the labour, you could easily spend 10 grand if the job is done by a Ducati expert and all top quality component fitted.
- BLABBERMOUTH
- BLABBERMOUTH
once again yup. ive owned this bike since new (purchased mid 1977) I rode it daily till about 85 .done heaps of work on it inc. motor rebuild. had a family etc. it sat in my dads shed till 94. i had moved to qld-got it up there -got it going &rode it a bit. got divorsed & moved back to adelaide- my 20 yo son had it for 2 yrs (bad decision) i now have it back in adelaide and am doing a ground up resto. i am nearly 50 yo and have deep pockets (luckily) but only want value which seems to be sparing given the rise in new bevel owners.anyway ill keep going with the resto and have sourced a lot of nos parts from unusual sources and am aiming to have a 100 % orig 1976 ss very soon.paid $3150 brand new -just spent $1000 on wheel parts -go figure
cheers steve
cheers steve
- BANNED
Hey Steve
Did you see that Borrani 4777 18 inch alloy rim at fleebay last week go for AU$2400 ? so I'm not surprised you paid 1k for parts , I have bought a bike about a month ago that has all SS gear including two matching 4777 rims but its not an SS .
All I need now is some SS cases and frame and I'll be right LOL but where do you find them these days ?
Did a 77 / 78 come out with Bosch ignition or did that happen on the 79 / 80 SS ?
- BLABBERMOUTH
900ss
hey martin
$2400 for a borrani ? think ill keep mine hidden under the mattress until i put em on the bike (soon).
new purchase with ss gear but not an ss? what was it ?
frame- mario sassi or a time machine
bosch elect- mines a 76 and has the dreaded duc. electronica stator plate.the 77 was exactly the same bike (rubber footpegs)if my memory is correct 78 ss took on some new darmah technology bigger crank pin;bosch elects.
- BLABBERMOUTH
ss wheels
hey martin
spent $956 on wheels
sprocket carrier-$255
spokes -$420
w-bearings -$132
spr. bearings -$26
front axle -$111 (sent me the wrong one)
nuys & washer -$12
tyres still to come,forks & triple trees still at painters-one expensive front end , but at least i already had borrani rims
spokes -$420
w-bearings -$132
spr. bearings -$26
nuys & washer -$12
