F1 Clutch slave cylinder O-Ring
hms86f1
Post by hms86f1 »
I have an F1 clutch slave cylinder w/ the o-ring inside the bore. I measured the original as OD=39MM, ID=31MM and cross-section=4MM. Is that correct? I found a source for an EPDM (brake fluid safe) O-ring of those metric dimensions but see that they come in different hardnesses: 40, 50, 60, 70, 75 and 90, the standard being 70. Does anyone know about the correct hardness?
Also, in the Pantah forum I saw reference to the O-ring size as "a-218" Is that a non-metric (inches) size equivalent?
Any clarification is appreciated.
* admin edit * Please click the link below to comment on another relevant post already in play...
viewtopic.php?f=39&t=3953
Re: F1 Clutch slave cylinder O-Ring
