Non high compression pistons for 750GT
- rightsideup
- Mariana
My GT is on the first oversize at the moment, compression readings seem low to me - 110psi rear and 100ish on the front. Should I be thinking of new pistons and the next oversize and if so, what recommendations for a 'normal' piston
'74 Ducati 750GT | '78 MZ TS250/1 | '97 Honda VFR750
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.
Re: Non high compression pistons for 750GT
Probably want to do a differential compression test first to determine valve as well as rings seal. Might save you a mort of work & $.
G
G
AKA a leakdown test.....
- rightsideup
- Mariana
Leakdown it is - thanks comrades!
