Led lamps in the Dashboard
Hi!
Has anyone changed the bulbs in the dashboard to LED lamps?
If so can anyone recommend where to buy the lamps?
I want some bulbs that doesn't melt the plastic.
Do you need a resistor if you just change the bulbs and not the socket?
Does anyone know what the socket i s called in the Mille dashboard?
Best regards
Hedton
Re: Led lamps in the Dashboard
hedton wrote: Sat Mar 03, 2018 11:37 am Has anyone changed the bulbs in the dashboard to LED lamps? If so can anyone recommend where to buy the lamps? <snip>
Yes, Hedton, it has been done (and it's easier to do these days than it used to be). I've had a quick look in my files, but unfortunately I can't find anything up to date with the info you want. If I do, I'll post again.
EDIT
According to Bevelhead Stephen Stepanian, these do the job. And I quote:
"You don't need voltage regulators or resistors for these, like you did the old 5 volt ones in the old "how to" article a few years ago on Ducati Meccanica."
https://shop.advanceautoparts.com/p/alp ... /6460004-P
hedton wrote: Sat Mar 03, 2018 11:37 am Does anyone know what the socket is called in the Mille dashboard?
You mean the lower piece of part #34 below? If so, just 'bulb holder', nothing more ... :)
Yes nr 34 with a resistor for led lamps.
I bought these..
https://www.ebay.co.uk/itm/10x-T5-LED-B ... 2749.l2649
Itemnr:332480267406
I'll report how the work
vij
Post by vij »
Did you get it to work in the indicator position too? I have to do some updates to my 1984 MHR 900, maybe add some diodes as the polarity is changing when I do left or right and this does not work with LEDs. Its very strange.
Jocke.
You need a new relay for the indicators such as this... https://www.diodhuset.se/blinkersrela-l ... gL3f_D_BwE
Best regards
Hedton
