Wheely not difficult! GTS
bobnorton
Post by bobnorton »
For some obscure reason i can't put my rear wheel back in, it would appear that the cush drive is holding off and not leaving enough room, no parts replaced so its just me , or have i missed something?.
Re: Wheely not difficult! GTS
Bob, Take the rubber spider thingy back out and flip it. The o ring section in the center is holding it off,should lay flat against the wheel side of the cush setup I think.This is from distant memory.Haven't had one apart in years but I remember having the same problem and flipping the rubber around fixed it.
bobnorton
Post by bobnorton »
Thanks , I must be getting old.
saraceno59
Post by saraceno59 »
I had my rear wheel out recently, to replace the bearings. The problem that i had was the rubber behind the sproket carier, i had to grease both sides to get it back in place. Once i did that i got the wheel back in, not very easily but with a little patience i have made it!
1973 GT750, 2000 SS750, 1996 Yamaha tenere 660, 1980 Yamaha LB50
