Someone might get a chuckle from this....
General discussion and gossip about Ducati and other Moto related issues - post your non-technical FAQs, comments & questions here. Most Moto related chit chat that doesn't really fit into one of the specific catagories should go in this area.
carlm
Post by carlm »
I took one of my headers into the local welding shop to fix a hairline crack on the lip. I needed to do this prior to sending them off to get them re chromed.
I just picked it up and here it is with the other one for comparison.
he even welded the washer:
A nice old boy that repairs boat props (amongst other things). I paid and left before I said something I'd regret later.
The one I was trying to repair had seen some abuse in the past - to the point where I was unable to slide the washer round the bend as the tube was a little distorted. So I probably should try and source another.... In the meantime I'm off to try the other welder.
Incidentally the washer does not appear in my parts book.
Re: Someone might get a chuckle from this....
bummer. i stock washers i had made up in stainless..
Crashfangio
Post by Crashfangio »
Wow. I wonder if he used a mask?? Lets hope he doesn't take up watch repairs...
73 750GT
rwhc80
Post by rwhc80 »
Struth Crash,
It looks like I've welded it for you, with my 120 amp stick welder that was given to me free. I've had 2 goes at it now , once to practice, Blew the fuses, and once to weld an upright on a trailor. 2 inch horizontal weld. took me 2 hours and 2 grinding disks !
I feel I'm getting better though, so give me a call, I think I'm ready to weld some alloy cases ???
Rick
SP3
Post by SP3 »
no chuckling here. you could save it with a die grinder, Dremel tool, some files, and a bunch of time. or, cut it off and (properly!!!) weld on a newly machined end.
1991 851 SP3
1966 250 Monza
1999 Monster 900
I've done a few of mine like that,laid on a bit more bead and some time with a grinder it comes out fine. If it doesn't leak appearance matters little as it is hidden anyway.
Return to “The Rumour Mill”
