Front caliper mounting
larslynn
Ok my 83 front brake calipers where always mounted at the rear of the forks, my mate has inormed me this is completely wrong I know I can swap them over etc etc but what difference does it make, I see in another post 83 MHR came with rear mounted calipers also see on youtube a guy called jcducati (check it out he has a Buell tank)has posted clips of his 83ssd with the calipers the same way on the rear. (Also has the same seat!! for all u ducati cops out there!) anyway thanks for the time.
Re: Front caliper mounting
For the answer to this - and much, much morelarslynn wrote:Ok my 83 front brake calipers where always mounted at the rear of the forks. My mate has informed me this is completely wrong. I know I can swap them over etc etc, but what difference does it make?
(Answer, btw, according to Ian: Calipers went behind the forks with the 1984 production (along with loads of other changes). Had happened in 1983, however, on the S2).
Diffference? Consensus seems to be, very little ...
