250 n/c top end rebuid
richied46z
Post by richied46z »
Hi guys, I'm rebuiding a 250 n/c. The rings were stuck, the the piston and bore seem ok. It has a 74.6 Borgo(sp) piston. Were can I get rings for it? And what shop do you recomend I buy parts from? I need the usual stuff to get this little gem back on the road. The crank looks to have been rebuilt already and seems tight.
Rich Dominguez
Chris Bushell
Post by Chris Bushell »
Rings are available from phil HItchcock roadrace@cci.net.au
Eldert
Post by Eldert »
E Bay seller gio655 has 74.6 piston rings listed on his website
the differend type Borgo pistons ( forged or cast ) have differend hight pistonrings so measure your rings before you order
the cast pistons have 2 oilcontrol rings where the forged pistons have one
Eldert
richied46z
Domi-racer
I talked to Kevin at Domi-racer yesterday and they had the rings I needed. I'm rebuilding two customer engines and I needed 74.6 and 75.0 piston rings. They also had the 31.5 fork seals I needed.
BTW Steve I checked your e-store and I will be buying one of your batteries and more than a few of those rubber parts.
Rich- up to my knees with Ducati single rebuilds.
