I've recieved a 1982 Pantah (complete but partially disassembled). It's been in pieces and off the road for the best part of 10yrs...but she's looking good...Clean but not immaculate. Engine's in the frame. Bit of an oil leak from the swing arm bush. Good cold compression (120psi on each pot).The carbies are going to need kits put through them. Wiring hasn't been removed since manufacture. Paint's good. Gave the wheels a good clean up. Calipers and pumpers have been rebuilt. The cold ground brake rotors are back on the wheels and the front wheel is good to go!!!
I've got a manuel for it but it is less than comprehensive.....
Does any one have a list of torque settings/values for major components?????
Also need a schematic/diagram for rear axle/brake assembly....?????
Strangley enough now that I sit back and look at it I've noticed that the previous owner had been riding around with the front brake calipers fastened to the rear facing aspect of the shokies. All the pictures I've seen show them on the forward side. Has some one muffed it and installed the shockie incorrectly (ie, mixed the left with the right) or is this some accepted practice????
CHEERS Kids!
I'm a moon faced hare-lipped, ham fisted, half-wit....I need all the help I can get...
