Gas cap seal - what's it take?
Desmo900SS
Post by Desmo900SS »
I have an 82 900SS and the gas cap leaks when you have anywhere near a half tank in it. I looked at the rubber seal and it still seams to be pliable. Are these easily replaced and should there be a second seal? Just looking for a reason this thing leaks. The cap has a key lock so I would prefer to fix this one versus just replacing it with another.
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Is your tank the later style that uses the same cap as an S2 ? you should be able to get seals for them both, if not of Steves shop shot me a PM and I'll send you the link
Desmo900SS
I think mine is the earlier style. In the US our 1982 model looks like a 1981 in the rest of the world. Mine appears to have only ever had one seal, but I was thinking there may have been two and the second one has just gone missing?
MartinMille BANNED
BANNED
Seals for the older caps are readily available from most Italian bike shops , check Steve's shop first
Yes I stock both sizes of the gas tank cap seals for twins, as well as both the sizes for singles. www.shop.bevelheaven.com
1 seal only is needed. Once you replace the seal (just remove the little screw etc it is a 2 min job) check that the cap is sitting on that little bar at the pivot correctly.. They typically do a good job of sealing up.
