Having rebuilt my 900ss with new gaskets and seals i have a tiny oil leak from the top of the rear bevel tube...( the tubes themselves were rechromed and new rubber seals fitted)
please some one tell me a quick and easy fix. !!!! (ie that does not involve removing the engine again )
over to you guys
cheers
Dave Burn
rear bevel tube weeping oil
Dave,
I wouldnt be too worried if this has only occurred within the first few times of kick over, I have rebuilt an engine recently and had the same issue, I took the bike out for a 60klm ride, and when I got home I thought I had forgotten to place seals! the O rings had not "swelled" to their extreme under heat and operation.
I wiped the bike down and let sit overnight, went out again next day and all was and has been fine! I had stainless bevel tubes and the standard orings in place. Its good as gold now. Hope you can be this lucky, just dont panic!
Grant
Grant
leaky tube
Unfortunately Grant i've been out a few times on the bike and still it weeps oil..its a tiny amount but enough to annoy the hell out of me !!!
cheers
Dave
cheers
Dave
leaky bevel tube
thanks for that....i had a similar thought as it happens. You can get a 0.1mm feeler gauge between the tube and the bevel carrier that houses the o ring, so i have carefully gone round the tube with the greased up feeler gauge to see if i can re-seal it...so far so good..fingers crossed here
cheers
Dave
cheers
Dave
Tom Willis
I replaced my tube orings twice before I examined the grooves. The casting in the back of the groove was pitted (probably that way since new). I cleaned the areas and added high temp silicone to the pitted areas only, installed the new oring and no more seeping. Apparently the oil was migrating around the outside of the oring and leaking.
Tom
