I checked the alloy magnetic trigger and centered the scribed line under the "S" mark to the key way on the crank about 20 degrees out! Not sure why, that has happened. Switched the ignition on, and turned the crank clockwise. Yellow LED out,checked front cylinder for TDC,correct . Nipped up grub screw and rechecked all good. Green LED lit ,hand crank again clockwise ,Green LED out,checked TDC on rear cylinder, correct.
Checked several times again,because its a real pain putting the starter gear back together again.
Just to put a spanner in the works.....a little red LED comes on ,at the pickup PCB,just to add to the confusion,probably to indicate that its working?
Watch this space,for the final out come......
