Just got a new 450 RR built, and (long story) the motor was supposed to be "Built To The Hilt". well --- that's not quite true, and though it has shown great promise, I need some coaching.
Although I can truly build BSA's & Triumphs blindfolded, with one arm tied behind my back -- I'm needing help doing the top end set up on the desmo. Not even pulled the rocker boxes off it, and would like some assistance from any Desmoexperti relatively local, that I can "look over shoulders" to help me get aquainted. The bike is drop dead gorgeous -- and needs to run as good as it looks.
bridiom@razzolink.com
Salinas, California. USA.
450 Desmo HELP !!
b5070
450 Desmo HELP !!
Brid Caveney.
Salinas.California.USA.
Valve adj.
Much worry about nothing. First of all, you may not need to adjust the valves at all. Checking the clearance is easy, just slip a feeler gauge in there and check it like the book says. If it's within tolerances, bolt the covers back on and go riding. If you do have to adjust them, just get a manual, whatever special tools you need, a micrometer or dial caliper, and pull out the old shims and replace with whatever thickness is needed to get the clearance you want.
Better not to rely on "experts," because most of them are not.
450 performance
Just an afterthought: Knew a guy who had a "drop-dead gorgeous" 450. He let me ride it once--what a dog. All noise and no go. My stock 350 Sebring with a bigger carb was way quicker.
450#2
Not to denigrate the noble 450, they can be made to run well, but the head needs a lot of work to make it breathe properly. No doubt, the one I rode had stock porting.
