Crank Rebuild Squarecase Early 860/900 Pre Bosch
VinceGTS900
Post by VinceGTS900 »
Hi there.
Have a '77 GTS that I am rebuilding. Can someone steer me in the direction of a crank re-builder. No obvious wear, but it is out of the engine and should be done.
Located in Arlington Va.
Vince
Re: Crank Rebuild Squarecase Early 860/900 Pre Bosch
Your best bet would probably be Malcome at Syd's Cycles in Fla. Falicon might still do them too but you would have to supply the rod/pin assy. [sit down before pricing the pieces]
VinceGTS900
Thank you
2013 HyperStrada
2010 KTM450 XC-W
1985 Mille S2
1982 Katana
1978 GTS900
1963 Bronco 125
