I have an 81 MHR and when I change the oil the drain plug only comes half way out before contacting the exhaust. This is my second Ducati with this engine, my first was an 82 900S2 and I'm sure I was able to remove the plug completely back then.
Anyway it still allows the oil to dribble out but I'm worried that the slow flow may leave sediment behind. The aftermarket side-stand is a blessing for getting the best angle to get the last drops out.
Also wondering if the shaft has a magnet on the end that may need cleaning.
Is this normal?
Should I removed the front header to get the plug out completely and maybe replace the washer each time?
Oil plug removal 81 MHR
Re: Oil plug removal 81 MHR
A quick look thru the parts books reveals that the bikes have different exhaust pipes. Part number 0769.84.520 for the MHR, 0803.84.202 for the S2. The 0769 code says that the pipe was originally used on a 1981 SS - which makes sense, given that the MHR was a dressed-up SS. The 0803 code is the S2 model.Dob8604 wrote:I have an 81 MHR and when I change the oil the drain plug only comes half way out before contacting the exhaust. This is my second Ducati with this engine, my first was an 82 900S2 and I'm sure I was able to remove the plug completely back then.
The various permutations of exhaust pipes is a feature of Ducatis at this time
Yes to both, IMO (nothing beats a full flush, does it?Dob8604 wrote:Should I removed the front header to get the plug out completely and maybe replace the washer each time?
Thanks Craig,
It makes sense, they probably brought the exhaust in closer to the motor on the MHR to get the fairing around it.
Since I only do about 2500km a year on it I'll take the exhaust off yearly when I do the annual oil change.
I suppose one good thing, I'll never lose the drain plug or drop it in the oil pan (as always seems to happen).
I dunno - I still manage to do it ...Dob8604 wrote: ... or drop it in the oil pan (as always seems to happen).
