Cylinder Head Interchange Question
Flat Ernie
Can you put desmo SD heads on a valve spring GT engine?
Flat Ernie
Jon Pegler
- Mariana
Flat Ernie
Thanks.Jon Pegler wrote:Only if you are very proficient in the use of machine tools.
You have to bore a hole for the closing rocker spindle, very accurately.
Even then, the spacing of the inlet manifold studs would preclude fitting 40mm carbs.
In short, the answer is no, unless you have access to a well equipped workshop.
