Last x-mas i treated myself to a disassembled 860GT. I am in the process of rebuilding the engine, about to install rings and piston onto the rear cylinder. Can anybody advise which of the two compression ring goes into the top groove. one ring is stepped and the other wedge shaped (keystone). Bores are good ring gap is less than 0.020thou so I want to build it up as it is and fettle out any faults then go for a full restore later.
John (ex-Rhodie)
860 piston rings
BEVEL DAVE
- Diana
john stringer
Thanks guys. I have the Ducati shop manual, also the Haynes but neither make any ref. I believe it was in one of Mick walker's books that there was a more detailed illustration but I'll go with your guidance.
Thanks.
As this is my first Duke are there any other tips?? I am paying very close attention to shimming on everything.
Thanks.
No real problems rebuilding a bevel twin, I did my first one with a Haynes manual and that worked out OK, just take your time and check everthing, previous owners are usually the biggest problem particularly with wiring. There are some horrible suggesions out there for getting around special tools usually involving hammers, making a copy of a genuine tool is not difficult but saves damage now and in the future.
Jock
Jock
