barn fresh 69 350 SSS
Just picked up a barn fresh 350 SSS. It is complete minus front fender and air filter. The motor is stuck. I do not have previous experience with the Ducati Singles. What is the best manual? I will have to remove the head to try to break loose the piston. Can this be done with the motor in the frame? What are some good Ducati shops in Northern Ca that could supply parts, etc? Only Ducati experience I have is with a 77 500 GTL from back in the day. Thanks -Preston
Stuck piston
Congrats to this jewel!
This might help, but be careful !
http://www.antique-engine.ns.ca/
Regards from Duesseldorf, Germany
Kuki
Kuki
Thanks for the info Kuki. My next step is to remove the head but I am waiting for a manual, I don't know how this bevel drive system comes apart yet.
I wonder if I could use the electrolosis method to loosen the stuck piston by pouring an electrolite into the bore (from what I can see throught the sparkplug hole the piston is near bottom of stroke), attaching the negative to the cylinder and suspending a positive electrode in the electrolite.
Red N' Blu
I know a couple of people with 350's that had poured Diesel fuel down the spark plug hole and let it soak in there for a few days. Both of the guys that i know that have used this method had luck, but only one succeeded with the piston removal because he made sure the pistion would not flop down on the connecting rod and cracked the skirt of the piston!!Maico 75 wrote:Thanks for the info Kuki. My next step is to remove the head but I am waiting for a manual, I don't know how this bevel drive system comes apart yet.
Good Luck! any pic's of the barn find??
I ordered some Kroil, it has Liquid Wrench and Marvel Mistery oil soaking in right now. Not sure if I'm going to have time to pull the head this weekend.
It seems as though it is not easy to post a picture on this forum. I sent Steve a picture via email, he may put it on the Bevelheaven website in the barn find pictures section.
