Hi Guys...just got a Condor 350, Swiss military bike...has the Ducati motor. She starts right up, but has a lot of tapping, sounds like its coming from the lower motor, almosts sound like she is running with no oil.
can anyone tell me what they think the problem is? thanks rob
CONDOR 350
Chris Bushell
- Parallel Twin
Assuming that the tappet clearances are correct, then it sounds like you are going to need to strip the motor and check it over.
It could be piston slap, but equally could be a loose clutch, alternator rotor or a big end flapping about.
Drain teh oil and look for bits of metal, if found do not run - strip it
Chris
Chris
CONDOR 350 GEAR PROBLEM
.Thanks for you response....She now wont go into 3rd and 4th gear...What do you think?????I appreciate your help!!!!
gear problems
Hi Guys.. I have a Condor 350, Swiss military bike...has the Ducati motor. Besides from be too noisey, she now wont go into 4th and 5th gear...Help?
