The other ones are coming from the top of the bevel shaft tubes. I tried rotating them to seat a miss-aligned o-ring and thought that might have done the trick, but they're back. So, looks like pulling the heads off this winter and replacing the seals. Background: the engine was just overhauled with all new gaskets, seals and o-rings. It has aluminum bevel shaft tubes that replaced the chrome plated ones.
I'm thinking about replacing the original o-rings with square-section rings:
or maybe "quad" rings
Anybody grappled with persistent bevel tube leaks using these types of seals as an alternative to the o-rings? Maybe some other approach that worked?
George
