Hit the first hurdle on the project.
I'm missing all of the kickstart components from the exterior lever to the inner shaft, gears & spring.
Split open another engine I had and its shaft is smaller diameter than the one on the 64.
Wanted: 64 Monza Kickstart shaft/internals
Re: Wanted: 64 Monza Kickstart shaft/internals
There are two different sets of internals, the older has a y-shaped spring to pull the gear back and the later had a coilspring.
You can spot the difference in the cases : the coilspring has two (or three can't check right now) holes drilled and tapped around the bearing of the kickstartshaft. The screws hold a small "bridge" in which the coilspring sits.
Shouldn't be too difficult to find those internals
