Mille S2 Oil Filter
Posted: Tue Nov 27, 2012 6:54 pm
by VinceGTS900
Can anyone tell me the part number or source for Mille oil filters. I ordered some from the UK but the screw on thread is the wrong diameter.
Vince
Re: Mille S2 Oil Filter
Posted: Wed Nov 28, 2012 4:10 pm
https://store.bevelheaven.com/engine-re ... ry-clutch/
Do you have a 1983/4 dry clutch? Yes those filters are different then ALL the other Ducati.......
Posted: Wed Nov 28, 2012 5:13 pm
by VinceGTS900
Thanks Steve, it is a 1985 Mille S2. I think mine has had the screw in the case changed to accept later filters. Investigating this weekend. I had a Mille filter and it has about a 17-18mm screw thread. The spigot on my engine is about 12mm and the filter I removed is taller than OEM one listed for the bike.
I will try to identify the filter that came off it.
Vince
Posted: Wed Nov 28, 2012 5:35 pm
yeah vince, if there is a manuf part number you should be able to get the spec on what it is for from your local supplier. I can;t imagine why anyone would change the filter type as ALL Ducati except for the dry clutch model I just mentioned, with a screw on type oil filter have used the same exact filter since the pantah engines to now. bevel drive of course are cartridge type and not what we are talking about...
by radecal
G'day Vince,
The Mille S2 will have the same filter as all belt drive Dukes. The MHR Mille has the same engine and takes the belt filters. No change to fitting size as they came from the factory that way.
Exception was the earlier MHR 900 transition model as it had the odd filter.
You can get 2 different height filters and the Mille engine is a pain if you use the taller filter as it is obstructed by the carby.
The thread size is the same.
Just get a filter for a belt engine and it will fit.
Posted: Sat Dec 01, 2012 5:12 am
by VinceGTS900
Thank you all.
So the filters I had were for the 900S2 dry clutch - hence the wrong year.
I have a spare filter for my MTS in the shed so that will go on this weekend.
I may get this Mille running in the coming week. Has been sleeping since 2000.
Vince
Posted: Tue Aug 29, 2017 3:44 pm
by hedton
My 1985 MHrMille has a spigot that is M16x1.5.
Should I change the spigot to an other diameter?
Best regards
Hedton
Posted: Wed Aug 30, 2017 10:00 pm
by hedton
My 1985 Mille has a 16x1.5 spigot.
I would like to change it to the later beltdrive thread.
Does the Pantah spigot fit?
Best regards
Hedton
Posted: Thu Aug 31, 2017 7:39 am
by hedton
I want the lower filter.
Cheaper filters and easier to find.
And as Steve says.
"Do you have a 1983/4 dry clutch? Yes those filters are different then ALL the other Ducati......."
I think that my 1985 Mille also have got this odd (M16x1.5)spigot.
Best regards
Hedton
Posted: Thu Aug 31, 2017 8:30 am
by hedton
Could you measure the thread next time you change the filter?
Best regards
Posted: Fri Sep 01, 2017 3:41 am
by hedton
Is this the filter that you use...
https://www.rexbo.eu/mahle/oil-filter-oc11?c=100259
If so, the thread is 3/4"-16UNF-2B
I bought a Pantah spigot but that one was M16x1.5 i both ends.
Best regards
Hedton
Posted: Fri Sep 01, 2017 4:11 am
by hedton
No, it doesn't fit, my spigot is M16x1.5 but the Mahle OC11 that I've got has a 3/4`-16UNF-2B thread.
See here.........
https://www.oljemagasinet.se/index.php? ... hle%20oc11
Or has Mahle OC11 got several different threads?
Best regards
Hedton
Posted: Fri Sep 01, 2017 5:51 am
by hedton
Do you know if yours is M16x1.5 or the 3/4`-16UNF-2B thread?
Best regards
Hedton
Posted: Thu Sep 21, 2017 12:52 am
by hedton
I bought this.......
http://www.ebay.co.uk/itm/AN-8-AN8-BLAC ... xy5jxSbx-F
Ebayitemnr:302337834959
With a little machining you can fit a 3/4 UNC filter such as the OC11.
I will take off the anodizing with 5 % of plumbing soda.
Hope this information is useful.
I've modified the spigot i bought.
And the Oc11 filter will now fit.
Posted: Fri Apr 02, 2021 9:44 am
by hedton
The filter is called w77 for the thread 3/4"-16UNF-2B.
https://www.google.com/search?q=w77+oil ... CAw&uact=5
