Page 1 of 2
250 cafe custom, #2
Posted: Thu Jun 24, 2010 7:43 pm
by joe1028
hi, one of the cafe bikes finished up...
duc 250
Posted: Thu Jun 24, 2010 7:44 pm
by joe1028
Posted: Thu Jun 24, 2010 7:45 pm
by joe1028
Posted: Thu Jun 24, 2010 7:46 pm
by joe1028
Posted: Thu Jun 24, 2010 8:28 pm
by joe1028
duc 250 and cb 750 cafe machines finished up last month
Posted: Fri Jun 25, 2010 3:20 pm
by TDF
I love it, wish mine looked that good. Did you make the tank or buy it somewhere?
TDF
Posted: Sat Jun 26, 2010 12:35 am
by joe1028
the tank /tail section is stock from airtech but modified for the narrow case.(slightly)
Posted: Sat Jun 26, 2010 12:37 am
by joe1028
under lh cover..heat formed abs inner fender,battery strap,cover brackets with rivnuts,clip in fuses and charge light.
Posted: Sat Jun 26, 2010 12:41 am
by joe1028
adjustable resistor for led tail light(running-brake off position) which was made up with 20 clear 3.3 v 25 ma leds, 110ohm resistors and then soldered onto a circuit board which was wired and mounted under the tail section to the frame.
Posted: Sat Jun 26, 2010 12:45 am
by joe1028
alum mirror with modified s/s attach hardware
Posted: Sat Jun 26, 2010 12:47 am
by joe1028
engine plates and hand removable oil dip stick with friction tab so cap will not come loose.
Posted: Sat Jun 26, 2010 12:48 am
by joe1028
operational airscoop and drilled lever.
Posted: Sat Jun 26, 2010 12:50 am
by joe1028
Posted: Sat Jun 26, 2010 12:52 am
by joe1028
alum pts cover,s/s retention straps.
Posted: Mon Jun 28, 2010 8:28 am
sweet bike
looks a treat, thanks for sharing the pix. Recommend you coat that tank with CASWELL tank sealer B4 putting gas in there.
