Re: BOSCH pick-up part #.
Posted: Wed Jun 06, 2012 6:28 pm
My motor is on the bench with the clutch cover side off the atm (I'm fitting IgniTech Pickups and making new mount plate),
I can have a look and see if there is any discernible numbers on the old Bosch pickups, will post up any info I can find tomorrow.
http://www.roadandrace.com.au/electrical_repairs.htm have reconditioned units or are you after NOS if you can find them?
Even then I would recommend rewiring them with heat/oil proof wires, pay attention to the polarity if you wire them backwards that cylinder will run at full advance
potentially destroying your starter sprag bearing if it backfires while starting.
Might be time to ditch the old Bosch system and go with a Sashe (sp?) or IgniTech
