750 Sport Headlight rivets ????
Posted: Wed May 13, 2009 12:30 am
by Gum
Gday, I have just had my head light re chromed, they had to remove the rivets that hold the brackets that attach it to the fork ears. Can these be obtained, or is there a nice bolt that can be used. I dont want to put an ugly rivet back it in. Im hoping that someone has been down this road before and can help. Thanks Gum
Posted: Wed May 13, 2009 2:53 am
by MartinMille BANNED
You should be able to get some blind rivets that will look close to what you had , try Blackwoods in NSW I think the rivets are called domed blind rivets or something like that
Posted: Wed May 13, 2009 3:41 pm
by GT Pete
I found this post from Steve in an old thread:
On the shells that I have restored, either painted or rechromed, I have drilled out the rivots to remove the bracket thing, done what needed to be done [chrome or paint] then reattach the bracket thing[s] with something that looked like a rivit head but had threads like a wierd nut. The top of the head is very low profile smoothe and round, under the head there are little ridges that bite into your material to keep it from spinning. I forget what they are actually called, but I want to call them rivit nuts from memory?????
You can get these at a harley davidson shop as they used them to attach fenders to the brackets on their older bikes. They work great and look the part and best of all are removable. Don;t forget to use lock tite...
_________________
Posted: Wed May 27, 2009 4:53 am
by conti-mental
Posted: Wed May 27, 2009 5:29 am
I went to the HD dealer the other day and they said nope we don't carry them , those ones look like the head size it was to large , you would have to lathe them down to be of any use for what you want
Let me know when you find some
Posted: Wed May 27, 2009 3:51 pm
by cafe*racer
Gum, I just drilled out these rivets on an original unit. FYI they were XXXaluminumXXX COPPER , not aluminum. You could turn some out of aluminum rod stock if so inclined. Jordan
Posted: Wed May 27, 2009 4:02 pm
Jordon
The issue is not finding aluminum rivets as you can get them from most Aviation workshops the problem is how do you get the rivets nice and tight without the proper tools !
The last thing you would want is for that "Jod" unit to fall out. Now that would make you cry
Posted: Wed May 27, 2009 4:34 pm
by cafe*racer
Martin, I have some experience with setting rivets, both hot and cold. It is a two person operation for sure and you do need proper tools and correct size rivets. That being said it is not difficult at all to get the rivets tight. Have more often than not seen the threads in the pivots wear out or get buggered before the rivets fail.
Posted: Thu May 28, 2009 9:57 pm
by cafe*racer
Sorry I had a brain lapse, went to the cave and double checked & ammended my previous post. The rivets were COPPER, not aluminum. Not that it makes much difference, both materials are soft enough to set easily.
