brembo calipers
Posted: Fri Nov 21, 2008 2:47 am
by nottonight68
brembo rebuild-vaseline or brake fluid when fitting seals ,pistons etc
Posted: Fri Nov 21, 2008 2:06 pm
steve use the lube that comes with the seal kits
DOT 4 brake fluid only remember....................
Re: brembo calipers
Posted: Fri Nov 21, 2008 2:08 pm
by Craig in France
nottonight68 wrote:brembo rebuild-vaseline or brake fluid when fitting seals ,pistons etc
Hi Steve,
Brake fluid, or the special* grease that should come supplied in a Brembo overhaul kit.
*Special = silicone based and does not damage natural rubber.
You can buy it separately - I guess Steve will have it, for example. But here's an illustration:
http://www.moto-racing.co.uk/item--Brem ... rease.html
