Page 2 of 2
Re: Better Oil Flow to the Sump, And filter ALL of the oil.
Posted: Tue Jan 07, 2025 4:12 am
by froggie
Ok thx.
Short answer is : yes :-D
Posted: Wed Jan 08, 2025 10:32 am
by Gardner
This engine also has a dry clutch from a Monster which helps keep the oil clean for longer.
Posted: Fri Jan 10, 2025 6:51 am
by froggie
Is that a plug and play swap? :?
Posted: Sat Jan 11, 2025 8:17 pm
by Gardner
No, not plug and play, but not terrible either. The hardest part was making the inner clutch drive with the right splines.
I really should have made more than one. It all fit nicely in the Brook Henry housing.
Posted: Sat Jan 11, 2025 8:21 pm
by Gardner
This is the backside.
Posted: Mon Jan 13, 2025 6:27 am
by froggie
Ok thank you.
But then, in addition, you change all the system of discs/plates to be "dry" instead of "in oil" and I suppose also that the oil circuit is changed accordingly?
Posted: Thu Jan 23, 2025 9:49 am
by Gardner
You can install a dry clutch without changing the oil circuit. I just did both at the same time. There is a dry clutch kit here on Bevelheaven.
Posted: Thu Jan 23, 2025 4:08 pm
Dry clutch kit for bevel drive twins with BOSCH ignition are in stock. Link below. I can get same for earlier square case as well as for round case, shoot me an email and I will get you hooked up.
https://store.bevelheaven.com/Clutch-Re ... on-Motors/
