Better Oil Flow to the Sump, And filter ALL of the oil.
froggie
Re: Better Oil Flow to the Sump, And filter ALL of the oil.
Post by froggie »
Ok thx.
Short answer is : yes :-D
Gardner
Post by Gardner »
This engine also has a dry clutch from a Monster which helps keep the oil clean for longer.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
froggie
Post by froggie »
Is that a plug and play swap? :?
Gardner
Post by Gardner »
No, not plug and play, but not terrible either. The hardest part was making the inner clutch drive with the right splines.
I really should have made more than one. It all fit nicely in the Brook Henry housing.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Gardner
Post by Gardner »
This is the backside.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
froggie
Post by froggie »
Ok thank you.
But then, in addition, you change all the system of discs/plates to be "dry" instead of "in oil" and I suppose also that the oil circuit is changed accordingly?
Gardner
Post by Gardner »
You can install a dry clutch without changing the oil circuit. I just did both at the same time. There is a dry clutch kit here on Bevelheaven.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Dry clutch kit for bevel drive twins with BOSCH ignition are in stock. Link below. I can get same for earlier square case as well as for round case, shoot me an email and I will get you hooked up.
https://store.bevelheaven.com/Clutch-Re ... on-Motors/
