Posted: Sat Oct 18, 2008 3:54 am
Ok I had another look at the pick-ups today and someone correct me on this if I'm wrong
The coils are mounted and are still mounted on the base plate I have not removed them at all, now the base place has a pivot point and adjustment bolt correct ? I'm assuming that the coils them self have to be aligned the the correct distance from the crank rotor , Isn't the adjustment bolt bolt there to adjust your timing ??? for when you install the timing sensor tool and I'm assuming you use a timing light on the front head to adjust the timing is that correct ?
