Marelli electronic ignition, single pick-up. The wiring diagram resembles the 906 paso wiring, but not completely. So if anyone could help, grazzi
Thanks in advance
Joost
Needed: '89 900SS wiring diagram
cafe*racer
- SSD900 Darmah
Joost, check this out http://www.bevelheaven.com/manuals/900S ... %20180.htm You can find this and other info here http://www.bevelheaven.com/manual-index.htm Let us know if this helps, Jordan
Hi Jordan,
Thanks for your reply. Before I posted this topic I checked beavelheaven.com (amongst a lot off other sites/places) for the manual/wiring diagram, but it seems like the 1989-1990 900SS manual is the only one which is not available somewhere.
As I said, it resembles the 906 paso diagram a lot. It uses a lot of paso parts, so (maybe..) that's not weird. The only major difference from the paso wiring is that the power/current to the ignition coils and electronic ignition unit is switched on/of by means of a solenoid that is operated by the run/off switch. I think that it has something to do with improving the the reliability/endurance (quicker switch on/off of the power) of the Marelli unit, because that unit is (and always was) a real problem child.
Anyway, this solenoid is causing major problems, and I prefer to rebuild the wire harness to the one used on a 906 (easier and normal application). But if there's a very good reason to use the before mentioned solenoid, it is beter to rebuild it in original state.
Joost
Joost
cafe*racer
- SSD900 Darmah
cafe*racer
- SSD900 Darmah
