I tried to post this message once, don't know where it went!
Just rebuil the PHF's, but it will only run on choke.....spits, coughs, backfires through carbs when choke is off. Goes way lean.
Jetting is per Ducati restoration guide.
Both carbs getting fuel.
New fuel.
Floats set per Dellorto guide.
Needles in mid position per restoration guide.
Can worn carbs cause this?
Thanks!
750GT rebuilt carbs, runs only on choke
Macca
Have also spent some considerable time setting up carbs , but found that the overhead gear must be right. Make sure the valve clearences are all to spec.
IBM
worry about the carbs first
I should not be allowed to give anyone carb advice, but, stupid question first, did you balance the carbs, if not check steve's balancing advice. If you did do you have any air leaks, check Steve's advice on finding these.
My motorcycle WAS older than my girlfriend.
Rebuilding the carbs won't do any good if you don't soak them in lacquer thinner for a half hour or so and then blow all the passageways out with compressed air.
Sounds like the low/mid range jetting circuit is plugged up.
