900SD Sprag Clutch Bearing?
Posted: Sat May 04, 2024 7:15 pm
by mb848
So I'm pretty sure I'm hearing the beginnings of the "coffee grinder" noise coming from the left side of my 900SD's engine. I'm not worried about digging into it eventually, but I was planning to ride the bike in the 2024 Distinguished Gentleman's Ride on May 19th and doubt I can have the parts delivered and replaced by then.
I was wondering, if I were to remove the chain between the starter motor sprocket and spindle and only operate it as a kickstart bike for the time being until I have the parts and time to replace the sprag clutch (maybe disconnect the starter motor in case I accidentally hit the button), would that remove the resistance the sprag clutch is free-wheeling against so that it's less likely to fragment on me if I keep riding the bike? :?
Re: 900SD Sprag Clutch Bearing?
Posted: Thu May 23, 2024 10:35 am
remove the starter chain. I have bearings in stock...
https://store.bevelheaven.com/Engine-Re ... g-Bearing/
