Oil plug removal 81 MHR
Posted: Sun Dec 02, 2012 10:49 pm
by Dob8604
I have an 81 MHR and when I change the oil the drain plug only comes half way out before contacting the exhaust. This is my second Ducati with this engine, my first was an 82 900S2 and I'm sure I was able to remove the plug completely back then.
Anyway it still allows the oil to dribble out but I'm worried that the slow flow may leave sediment behind. The aftermarket side-stand is a blessing for getting the best angle to get the last drops out.
Also wondering if the shaft has a magnet on the end that may need cleaning.
Is this normal?
Should I removed the front header to get the plug out completely and maybe replace the washer each time?
Re: Oil plug removal 81 MHR
Posted: Wed Dec 05, 2012 3:00 am
by Craig in France
Dob8604 wrote:I have an 81 MHR and when I change the oil the drain plug only comes half way out before contacting the exhaust. This is my second Ducati with this engine, my first was an 82 900S2 and I'm sure I was able to remove the plug completely back then.
A quick look thru the parts books reveals that the bikes have different exhaust pipes. Part number 0769.84.520 for the MHR, 0803.84.202 for the S2. The 0769 code says that the pipe was originally used on a 1981 SS - which makes sense, given that the MHR was a dressed-up SS. The 0803 code is the S2 model.
The various permutations of exhaust pipes is a feature of Ducatis at this time :doh: . As well as as the styling changes, the factory was having to find ways of reducing noise emissions to meet the higher standards - which is why we got blessed with those half-ton Silentiums ...
Dob8604 wrote:Should I removed the front header to get the plug out completely and maybe replace the washer each time?
Yes to both, IMO (nothing beats a full flush, does it? :shock:. And always replace a 2-cent crushable washer unless you particularly like oil leaks ;) ). No magnet at the end, btw.
Posted: Wed Dec 05, 2012 12:15 pm
by Dob8604
Thanks Craig,
It makes sense, they probably brought the exhaust in closer to the motor on the MHR to get the fairing around it.
Since I only do about 2500km a year on it I'll take the exhaust off yearly when I do the annual oil change.
I suppose one good thing, I'll never lose the drain plug or drop it in the oil pan (as always seems to happen).
Posted: Thu Dec 06, 2012 12:34 am
by Craig in France
Dob8604 wrote: ... or drop it in the oil pan (as always seems to happen).
I dunno - I still manage to do it ... :doh: :shock:
