Mainshaft / Layshaft
Posted: Wed Nov 14, 2012 9:33 pm
by sd900
Hi all, I believe I have the transmission right, but wanted to know if there's any procedure or test to make sure I do before I put the cases back together? I'm assuming there's only one way the shifter hub goes back in place with the shifter forks in the the right grooves, but maybe I've been wrong before. A couple of pics attached. Any advice appreciated. Thanks.
s
Re: Mainshaft / Layshaft
Posted: Thu Nov 15, 2012 6:39 pm
by wdietz186
Leave the crank out,kickstart stuff too, and put the cases together and spin the shafts while moving the selector drum and watch through the cyl. holes to see the gears engage. Endless hours of fun! It all looks OK in the pictures. A good time to check the endfloats too.
Posted: Sat Nov 17, 2012 1:17 pm
by sd900
Hours of fun, indeed. Thanks for the reply. If I don't have it right, is it a question of repositioning the shifter hub? I haven't removed any cogs off the shafts, etc., so I'm fairly certain they're ok. Thanks again.
s
Posted: Sat Nov 17, 2012 7:04 pm
by wdietz186
If the forks are in the wrong positions it won't shift through all the gears.From what I can make out in the pics you've got it right.
