1978 900SS Konking out
Posted: Wed Oct 31, 2012 10:38 pm
I have just finished a bare frame rebuild of my 1978 900ss (Black and Gold) which I have owned and ridden in Darwin Oz since 1979. It was off the road in boxes for the past ten years but now looking great. It was always a fairly reliable bike in wet or dry and after I got it back on the road it was just as reliable. However now it has a real problem - after starting it just konks out - just like the ignition was turned off - both cylinders at once. Doesnt feel like a fuel problem - its both cyliners at once. Also I have replaced the Bosch ignition both sides recently but this konking out is both cylinders so I dont thnk its the Bosch ignition. I have replaced regulator (needed to anyway) cleaned up fuse box and earth - no change. Starting to drive me nuts! Any suggestions? Must be electrical and something common to both cylinders. Maybe the stator? But would that cause it to konk out? Maybe something to do with the wiring - probably. I had a auto electrician (seemed competent!) re-wire the switch block to the loom wiring and also the wiring to the idiot lights. Anybody experienced this one?
