Front Axel Nut Torque Setting
Posted: Wed Apr 29, 2009 6:14 pm
by peaky
On a 78 SD Darmah, what is the torque setting for the front wheel spindle nut? How about the clamp bolts?
Thanks! Scott in Florida
Posted: Thu Apr 30, 2009 7:51 am
by wdietz186
Scott, I use tight and snug respectivly. It probably amounts to about 40 and 15ftls.
Posted: Thu Apr 30, 2009 1:04 pm
by Craig in France
Hi Scott,
Torque settings for Ducatis can be difficult to find ... in which case, what I do is to pick a similar bike and use whatever is given for it.
So, for example, for the nuts you're talking about, the recommended values quoted for the Laverda RGS (same forks, same wheels) are:
Axle: 52-59 ft/lb
Fork clamp bolts: not specified.
Normally, when there's no value quoted for a specific bolt, it's because it's no different from the standard value for a 8.8 bolt of the given diameter (in this case, I suggest this is because these bolts are not especially stressed - they just need to stay done up :) ).
And the standard setting for a 8.8 bolt, 8mm x 1.25, is 29 Nm or 21 ft/lb.
P.s For these bolts, I always use nylocs.
Posted: Thu Apr 30, 2009 7:51 pm
by peaky
Thanks gentlemen! Any idea of the torque settings for the rear spindle nuts?
Posted: Fri May 01, 2009 11:37 am
by Craig in France
peaky wrote: ... Any idea of the torque settings for the rear spindle nuts?
Hi Scott,
Not surprisingly, it's the same as the front :)
(It's the same size bolt made from the same grade steel with the same pitch thread doing the same job = same torque.)
Posted: Fri May 01, 2009 1:52 pm
by peaky
Wow! :shock: My rears are WAY over-tight! :o I hope I haven't overloaded the bearings :x
Thanks to Craig! :-D :-D
