Darmah to get back in action after 13 years
Posted: Tue Mar 31, 2009 1:49 pm
Hi there !
Got my Darmah out of the corner of my garage to get it back to work.
It was stored when I went over to Iowa in 1996/97. My brother drove it a little then, but I just put it into the garage when I came back to Germany.
The condition is better as I remembered, the engine was overhauled and ran great (until it began to bang a little - may be valves just need to be adjusted !?). Any tips ?
Btw - do you guys use unleaded fuel ? I had to put in some special lead additive back then, when the leaded fuel in Germany was forbidden. Were american Darmahs always equipped with hardened valve seats ? I wonder, if I still need to use this lead stuff......
I was shocked, when I opened the gas tank today. I filled it up in 1997 - never took a look into the tank again. See the rust ! Hopefully it is just a crust, that fell down from the lid, because the lid seems to be the source of rust. I will remove the tank, empty it, claen it and (if necessary) restore and seal it.
Before moving the engine, I will take a look inside the cylinders - hopefully no rust there !
I do have a set of Contis and the '79 seat/tail assembly as well (like that more). I payed more than € 100,- just for a used seat leather/foam cover ! Payed € 25,- for the set of Lafranconis in new condition - but that was about 15 years ago .....
Watch the oil pipe from crank shaft to the self made oil filter housing ! Fresh filtered oil gets directly to the crank shaft.
Any tips/commends welcome
Best regards from Germany
Joe
http://www.funpic.de/fotoalbum/foto,257233,0.htm
http://www.funpic.de/fotoalbum/foto,257232,0.htm
http://www.funpic.de/fotoalbum/foto,257234,0.htm
http://www.funpic.de/fotoalbum/foto,257235,0.htm
Joe
