Early 860 Primary gear on a late Bosch ignition crank:
Posted: Fri Mar 13, 2009 8:11 pm
by Desmo900SS
Does anybody know if the early style primary gear (I think it is from a 1975 860) will fit on the later (1981) bosch ignition style crank? I have a trashed primary gear (cracked) and need to replace it. It appears that all styles of these gears use six allen bolts and two pins so I hope all that I can use the older gear with the later flywheel... (because I can't find a later gear).
Posted: Thu Mar 19, 2009 3:22 am
by MartinMille BANNED
This is of a 79 Bosch engine and as you can see the teeth are in good condition
PM me if you need it.
Posted: Thu Mar 19, 2009 6:06 pm
by wdietz186
Ya know that flywheel looks like the same piece installed on the 750 GT
