Changing engine lubricant
Posted: Mon Jan 14, 2013 6:34 pm
by GHamilton
1980 900 SS. Should I put new oil in 'til it shows correctly on the dipstick, or remove the left side cover/plate and put in the amount shown in the manual? Although I've never tried it, I've heard that the amount in the manual cannot be put in through the dipstick hole. Is this correct, and would it shorten engine life if this method is followed.
Gordon
Re: Changing engine lubricant
Posted: Mon Jan 14, 2013 7:30 pm
by wdietz186
Fill it to the level on the dipstick. No need to worry about undue wear or poor lubrication due to level,the oil is picked up from the bottom of the sump and pumped into the crank and heads.The oil returning from the heads and the oil squeezing out from the crankpin gets thrown onto the transmission by the spinning crankshaft.With about a gallon of oil in circulation everything is kept happy/oily
Posted: Mon Jan 14, 2013 7:41 pm
by GHamilton
Yeah, I figured that enough oil would circulate to keep the motor happy, but if there is MORE oil to circulate around, would that not be a plus and help with cooling also, hence less stress on the engine?
Gordon
Posted: Tue Jan 15, 2013 3:03 am
by Craig in France
Like wot Bill said, Gordon: Fill to the upper mark on the dipstick.
(It's actually the same as the lip in the sump, btw. So, once you've got the hang of it, you'll find you don't need to keep re-dipping the stick).
You won't get in the full amount 'cos there's always a bit of oil left in the engine after a draining. Take the lower valve cover off the front pot and you'll see what I mean .. :).
More oil won't improve the lubrication of the engine and will just get blown out the breather (or elsewhere). And don't worry about extra cooling capacity. Ign T. made sure his engines have plenty of oil and ample cooling. You only need to add a cooler if you're racing ( ... and then you need to also think about the drain rate back to the sump. But let's not go there ... :| )
