Camshaft identification on Desmo's is there any ?
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Hi All
Is there a way to tell what cam is from what engine on a desmo head ?
are there any marking's on them to tell them apart ?
The cams had paint marks on the bevel end of the cam .I don't remember exactly but I'm pretty sure the Imola cams had Blue/Black paint on them . Black/Green was for the normal Darmah I think.
MartinMille BANNED
BANNED
Thanks for that
One would think that the paint would wear off at some point
anyone know what SS cams have on them ?
nottonight68
BLABBERMOUTH
Post by nottonight68 »
hey martin
seem to remember blue & yellow
coloured dots were also on heads-between rocker covers
cheers
conti-mental
Post by conti-mental »
Seconded!
My SS had yellow & blue paint dabs on the heads - a real shame I had to bead blast those heads :(
No paint marks on the cams though...
Just remembered I got a photo before the foul deed!
While we're 'on topic' I've got a question - did all SS's have polished rockers?
Cheers!
Andy[/img]
MartinMille BANNED
BANNED
This is the same situation that I found myself in after the engine beading ,no marks to let you know what cam is in your engine , and now what sure I can remove the cam etc etc but there is still no way of telling what it has inside ,frustrating to say the least
Martin, As I recall my 77 900 had the blue yellow marks too. You could check the timing events when you have it back together. I'm pretty sure the timing figures are in the service manual. Take a look in the manuals section on this website. Checking involves a degree wheel and a dial indicator. Just remember to turn the crank clockwise[looking at it from the primary side] as it spins backwards compared to normal[read pedestrian] motorcycles. Conti-Mental,the rockers came from Ducati copper plated with flash chroming on the contact pads.
MartinMille BANNED
BANNED
Well found some more for you guys about what Cam's are in what bikes
Looks like Ducati 900/1000 cams are all the same grind no matter what colored dots are on the heads
That NCR cam looks like a bit of wild gear 8)
1975 / 1981 -900SS - Cam
1979 / 1982 SD
ALL MHR 900/1000
Inlet opens 63°
Inlet closes 83°
Exhaust opens 80°
Exhaust closes 58°
And all NCR's 750 or 900 had this grind
1975 / 1979 750/900 NCR Cam
Inlet opens 70°
Inlet closes 100°
Exhaust opens 100°
Exhaust closes 70°
