wanted: conti
Posted: Tue Nov 29, 2005 6:55 pm
hi. I am interested in finding a set of contis for a '78 900 gts. any info would be helpful. thanks
CR
CR
Ducati Maintenance, Preservation & Restoration
https://www.forum.bevelheaven.com/
Chrome is transparent. You need more copper and polishing to fill and fix the pits. Then the polished and buffed nickel is for the chrome to stick to.Geoff wrote: They also have a repair to the inside of the RHS one where the PO mal-adjusted the spindle and cut the conti! And they've still got some evidence of pitting on them even with the nickel on (hopefully that would cover up with the chrome).
Noted Den; looks like they're off to eBay then!! With that health warning... Cheers!Den wrote:Chrome is transparent. You need more copper and polishing to fill and fix the pits. Then the polished and buffed nickel is for the chrome to stick to.Geoff wrote: They also have a repair to the inside of the RHS one where the PO mal-adjusted the spindle and cut the conti! And they've still got some evidence of pitting on them even with the nickel on (hopefully that would cover up with the chrome).
