Wanted: Front signal threaded hollow rods
confusa
Post by confusa »
I need a pair of the hollow threaded rods that the front signals mount on. The ones that would be used if you had the wire headlight mounts on a 750, 860, or 900. Basically open on both ends, threaded all the way. Have had no luck at hardware stores, etc. Anyone has a pair lying around let me know. PM or email confusa(at)speakeasy(dot)net.
Re: Wanted: Front signal threaded hollow rods
You need to specify if threads are to fit APRILIA or CEV turn signals in order to get what you want.
confusa
Post by confusa »
Ahh, didn't know it made a difference. Mine are Aprilia.
BevHevSteve wrote:You need to specify if threads are to fit APRILIA or CEV turn signals in order to get what you want.
Return to “Bevel Drive Twins”
